$84.95... not happening.
Sabaism
I just got my new MD (MZ-N510) and went to look for a Optical cable so I can ue my stereo. (Computer crapped out and it'll be awhile before I get a new one.)
After failing to find the recommended cables I contacted Sony. The solution was to buy a $84.95 cable. Model number POC-DA12SP. This ain't going to happen. Can i use another cheaper cable? Or will it cause my MD to blow up?
Thnx.
Welcome. Any of these will do, I imagine.
http://froogle.google.com/froogle?q=toslin...F-8&sa=N&tab=wf
What you need is a Toslink [stereo] to Miniplug [MD] connector.
You must make sure that the digital out on the stereo is a Toslink connector! If it isn't, you need a miniplug to miniplug connector. Most stereos are Toslink > Miniplug, however..
Yep, you've got an optical out. There's a section in the schematic under Main Section 3/5 F13 where it says there's a digital out (IC402, TOTX178) which is an optical transmitter. Bear in mind that the TOTX178 will only work on optical cables less than 5m in length.
Pretty cool stuff, btw. The power amp stage has a built-in thermostat for overheating protection. tongue.gif
I just told you what it is. Read up.
You gave me the link, I gave you the reference. Surely you can check the page that says section 3/5 and look for the grid number. :
In in doubt, Google is your friend.
Shoot, forgot to mention the page locked up on me. Couldn't do anything with the page, even close it. Also, obvisously, I had a brain fart. :wacky:
I got to get that page to work. You really shouldn't know more about my stereo than me. lol
OUt of all on that list (thnx again BTW) I heard of only one and it wasn't good. Anyone out there like one of these companies over another?
